10. A balanced star connected three phase load has a coil of inductance 0.2 H and resistance 50 in each phase. It is supplied at 415 V, 50 Hz. Calculate EACH of the following:
(a) the line current;
(b) the power factor;
(c) the value of each of three identical delta connected capacitors to be connected across the
same supply to raise the power factor to 0.9 lag;
(d) the new value of the line current.
