Class 2 (2nd Engineer) SC&S 📅 Jan 2026
Q8 (a) Describe the fundamental principle of a propeller. (6) (b) A propeller 6m in diameter has a pitch ratio of 0.9, BAR 0.48, and, when turning at 110 rev/min, has a real slip of 25% and wake fraction 0.30. If the propeller delivers a thrust of 300 kN and the propeller efficiency is 0.65, calculate: (10) (a) Blade area (b) Ship speed (c) Thrust power (d) Shaft power (e) Torque
### Part (a): Fundamental Principle of a Propeller
A marine propeller generates thrust to propel a vessel by converting the rotational power from the main engine into hydrodynamic force. The fundamental principle is based on a combination of Bernoulli's principle and Newton's Third Law of Motion, applied to the propeller's blades which act as rotating hydrofoils.
1. **Hydrofoil Action (Bernoulli's Principle)**:
* Each propeller blade has a cross-section similar to an aerofoil, known as a hydrofoil. The face of the blade (pressure side) is relatively flat, while the back (suction side) is cambered or curved.
