Class 2 (2nd Engineer) MEKG 📅 Mar 2026
Q8 (a) Describe, with the aid of a Strain versus Time diagram, how a creep test is carried out to determine the strain rate of the material under test. (8) (b) Explain EACH of the stages sketched in the diagram in part (a). (8)
### (a) Creep Test Procedure and Strain vs. Time Diagram
#### Concept of Creep
Creep is the time-dependent, permanent deformation of a material subjected to a constant load or stress at an elevated temperature. It is a critical consideration for components operating under high temperatures for extended periods, such as turbine blades, boiler tubes, and high-pressure steam pipes.
#### Test Apparatus and Setup
