Class 2 (2nd Engineer) MEKG 📅 Mar 2026
Q9 (a) Explain the action of EACH of the following metallurgical mechanism: (10) (i) Creep (ii) Brinelling (iii) Fretting (b) State, with reasons, where EACH of the mechanisms in occur in ship propulsion System (6)
### Part (a): Explanation of Metallurgical Mechanisms
#### (i) Creep
**Concept:**
Creep is the time-dependent, permanent plastic deformation of a material subjected to a constant stress (or load) at elevated temperatures. This deformation occurs even if the applied stress is well below the material's yield strength at that temperature. It is a thermally activated process, becoming significant at temperatures exceeding approximately 40% of the material's absolute melting point (0.4 T_m).
