Class 2 (2nd Engineer) MET 📅 Mar 2026
4. a) Explain what is meant by the term single phasing.(5) (b) Explain the probable effect of single phasing on a delta connected squirrel cage induction motor on 75% full load.(5) (c) State a method by which a motor can be protected against the effects of single phasing. (6)
### (a) Explanation of Single Phasing
Single phasing is a fault condition in a three-phase electrical system where one of the three supply lines (or phases) to a piece of equipment, such as an induction motor, becomes open-circuited. The equipment, designed to operate on a balanced three-phase supply, is now forced to operate on only two phases.
**Key Characteristics and Causes:**
* **Loss of a Phase:** The fundamental issue is the complete loss of voltage and current flow in one of the three conductors (e.g., L1, L2, or L3).
