Class 2 (2nd Engineer) MET 📅 Mar 2026
9.a) List the factors that determine the maximum developed torque of the induction motor. (6) b)The primary and secondary windings of a 500 KVA transformer have resistances of 0.42 and 0.0019 respectively. The primary and secondary voltages are 11 000 V and 415 V respectively and the core loss is 2.9 kW, assuming the power factor of the load to be 0.8. Calculate the efficiency on (i) Full load. (ii) Half load; (10)
### Part (a): Factors Determining Maximum Developed Torque of an Induction Motor
The maximum torque, also known as breakdown or pull-out torque, is the highest torque an induction motor can produce. The key factors that determine this value are derived from the torque equation:
$$ T_{max} = \frac{k \cdot V_1^2}{2X_2} $$
Where:
