Class 2 (2nd Engineer) MEKG 📅 Aug 2018
A rudder of a vessel requires extensive welding repairs and as Second Engineer you are requested to supervise the repairs:
(a) Suggest a suitable type of welding process.
(b) State, with reasons, FOUR common welding defects.
(c) State what tests may be carried out before returning the rudder to service.
As Second Engineer, I would oversee the extensive welding repairs required for the vessel's rudder using the following plan:
(a) Suitable Welding Process:
Manual Metal Arc Welding (MMAW), also known as Shielded Metal Arc Welding (SMAW), is the most suitable process for this repair. The reasons are threefold:
MMAW is highly portable, allowing for on-site repair within the drydock. The process is adaptable to various welding positions (downhand, overhead, horizontal, vertical) – a necessity given the complex geometry of a rudder.
