Class 2 (2nd Engineer) SC&S 📅 Aug 2019
A ship 150 m in length, 24 m breadth, displaces 25000 tonne when floating at a draft of 9 m in sea water of density 1025 kg/m?. The ship's propeller has a diameter of 5.8 m, a pitch ratio of 0.9 and a blade area ratio of 0.45. With the propeller operating at 2 revs/sec, the following results were recorded:
Apparent slip = 0.06
Thrust power = 3800 Kw
Propeller efficiency = 64%
The taylor wake fraction Wt = 0.5Cb-0.05
Calculate each of the following for the above condition:
(a) The ship's speed
(b) The real slip ratio
(c) The thrust per unit area of blade surface
(d) The torque delivered to the propeller
Given:
$$L \space = \space 150m$$
$$B \space = \space 24m$$
$$D \space = \space 9m$$
