Class 1 (Chief Engineer) Engineering Management 📅 Apr 2022
A ship sustained damages on hull while birthing. Your inspection revealed that on port side there is a damage to shell plating. You observed a deep dent on shell plating of 20 mm thick for approximately 2 square meter. This shell plating has to be removed and replaced along with the relevant damaged stiffeners which have been set up.
As a Chief Engineer officer of this ship, write a dry dock specification for the repair of the above mentioned damage that has occurred, stating what factors have to be considered when costing the repairs.
### **Dry Dock Repair Specification for Damaged Hull Plating**
**Job Specification No.:** [Vessel Name]/Hull/2024/01
**Vessel:** [Vessel Name]
**Location of Damage:** Port Side Shell Plating, In Way of [Specify Tank/Compartment, e.g., No. 3 WBT]
