Class 2 (2nd Engineer) SSEP 📅 Jan 2026
Q2 (a) Sketch a line diagram of a mechanical high expansion foam fixed firefighting system suitable for machinery spaces. (6) (b) Describe the operation of the system sketched. (6) (c) Explain how a mixture of foam making compound and sea water are converted into foam. (4) (d) What are the periodic maintenance required on the system. (4)
### (a) Line Diagram of a Mechanical High Expansion Foam System
A line diagram would illustrate the following key components arranged logically to show the flow from water source to foam discharge:
1. **Sea Water Supply:** A connection from the ship's fire main or a dedicated sea water pump, complete with a main isolating valve.
2. **Foam Concentrate Tank:** A tank containing the high-expansion foam liquid concentrate, fitted with a level indicator, filling connection, and a vent.
