Class 2 (2nd Engineer) SSEP 📅 Jan 2026
Q4 (a) Sketch a simplified circuit that may be incorporated in a control panel for an array of fire detectors. (8) (b) Describe the following features that may be found in a control panel for fire detectors: (i) Audible fire alarm circuits. (4) (ii) Identification of zone of fire (4) (iii) Automatic change over from normal power supply (4)
### Part (a) Simplified Fire Detector Circuit
A typical fire detector circuit is designed to be 'fully supervised', meaning it can differentiate between a normal state, a fire (alarm) state, and a fault state (e.g., a broken wire). This is achieved using an End-of-Line (EOL) resistor.
**Circuit Components:**
* **Control Panel:** The central processing unit containing monitoring logic, relays, power supplies, and indicators.
