Class 2 (2nd Engineer) MET 📅 Mar 2026
8.a) What is a silicon controlled rectifier (SCR) ? How is the breakover voltage of the SCR defined? (6) b) A d.c. motor takes an armature current of 110 A at 480 V. The resistance of the armature circuit is 0.22. The machine has six poles and the armature is lap-connected with 864 conductors. The flux per pole is 0.05 Wb. Calculate (a) The speed; (b) The gross torque developed by the armature.(10)
### Part (a): Silicon Controlled Rectifier (SCR)
#### 1. Definition of an SCR
A Silicon Controlled Rectifier (SCR) is a three-terminal, four-layer (P-N-P-N) unidirectional semiconductor switching device. It is a type of thyristor, primarily used for controlling high-power AC or DC circuits.
* **Terminals**: It has three terminals:
