Class 2 (2nd Engineer) MEP 📅 Jan 2024
(a) As second engineer, describe the procedure involved in the complete inspection of a cylinder liner and piston assembly, indicating areas of significant interest. (5)
(b) Explain with reasons, possible faults which might be found. (4)
(c) Suggest how such faults might be avoided. (4)
(d) How liner wear and wear rate is calculated? (3)
(b) Faults in cylinder liner:
Cracks on the liner due to excessive tightening/ incorrect tightness of cylinder liner bolts
Cracks due to hoop stress because of poor liner support
Circumferential cracks along the wear ridge due to stress concentration or, more likely, because of new rings hitting the ridge
