Q2.
Auxiliary engine components often face demanding service conditions. Analyse how the addition of alloying elements (such as silicon, chromium, and manganese) to cast iron influences the corrosion resistance, hardness, and thermal stability of these parts. Provide examples of auxiliary engine components that benefit from such alloying.
(16)
### Introduction to Alloying Cast Iron Cast iron is a fundamental material for marine auxiliary engine components due to its excellent castability, good damping properties, and relatively low cost. However, standard grey cast iron has limitations in terms of strength, corrosion resistance, and performance at high temperatures. To meet the demanding service conditions of a marine environment—which include high thermal stresses, corrosive combustion by-products, and significant wear—alloying elements are added to the iron-carbon matrix. These elements modify the microstructure and impart specific properties, transforming the base material into a high-performance engineering alloy suitable for critical applications. ### Influence of Alloying Elements on Cast Iron Properties #### 1. Silicon (Si)
