Class 2 (2nd Engineer) MEKM 📅 Jun 2025
(a) Briefly State and describe the various heat treatment processes applied to cast iron main engine components. (4)
(b) How do these treatments modify the microstructure and mechanical properties of the components? (6)
(c) Provide examples of how heat treatment can improve wear resistance, strength, and service life in main engine parts. (6)
Cast iron, particularly grey and ductile iron, is widely used in main engine components due to its castability, durability, and cost-effectiveness. To enhance performance and extend service life, these components are subjected to different heat treatment processes , which modify their microstructure and improve mechanical properties.
(a) Heat treatment processes applied to cast iron engine components
Stress Relief Annealing: This process involves heating the cast iron to a sub-critical temperature (500-650°C for gray iron, 500-550°C for ductile iron) and then slowly cooling it. This treatment's main purpose is to reduce or eliminate residual stresses from casting and machining, preventing warping and distortion.
Annealing: Annealing is used to soften the cast iron, making it more machinable and ductile. The component is heated above its critical temperature range (870-925°C for full annealing) or to a sub-critical temperature (705-720°C for subcritical annealing) and then slowly cooled.
