(a) By means of a schematic circuit diagram illustrate the peak rectifier. If the supply voltage is v(t) = Vm Sin wt. what is the voltage across the load resistor? (6)
(b) A d.c. motor takes an armature current of 110 A at 480 V. The resistance of the armature circuit is 0.2 Ω. The machine has 6 poles and the armature is lap connected with 864 conductors. The flux per pole is 0.05 Wb. Calculate: (10)
(a) The speed,
(b) The gross torque developed by the armature.
