Class 2 (2nd Engineer) MET 📅 Aug 2018
Compare methods of obtaining speed regulation of three-phase induction motors generally used in tankers by means of:
(a) Rotor resistance
(b) Cascade system
(c) Pole-changing
Give examples where each system may be employed with advantage.
Three main methods of speed regulation for three-phase induction motors used on tankers are rotor resistance , cascade system , and pole-changing .
Each method operates on a different principle and is suited to particular shipboard applications depending on the load, torque, and speed control requirements.
(a) Rotor Resistance Method
Principle:
