Class 1 (Chief Engineer) Engineering Management 📅 Jan 2022
Define Communication; Enumerate and discuss the different types of communications. Discuss the various barriers to effective communication.
You are doing a Main engine decarbonisation and work is carried out in two groups, One working on the cylinder head platform and the other group working in the bottom platform. Identify the areas in this operation where there can be a hazard due o failure of communication. Also suggest risk mitigation measures to mitigate this hazard of failure of communication
### 1. Definition of Communication
Communication is a fundamental two-way process of exchanging information, ideas, feelings, and meaning between two or more participants. It is not merely the transmission of a message but also its reception and comprehension. Effective communication ensures that the intended message is received and understood by the receiver as intended by the sender. In a maritime context, and particularly in engineering operations, clear, concise, and unambiguous communication is paramount for safety, efficiency, and the successful completion of tasks.
### 2. Types of Communication
Communication can be broadly categorized into the following types, each with its own advantages and disadvantages in a shipboard environment:
