Class 4 (4th Engineer) MEKG 📅 Feb 2026
(a) Define creep and specify the conditions under which it occurs? (6) (b) Discuss three metallurgical/processing techniques that are employed to enhance the creep resistance of metal alloys. (10)
### (a) Definition and Conditions of Creep (6 Marks)
#### Definition of Creep
Creep is the time-dependent, permanent (plastic) deformation of a material subjected to a constant stress or load, which is below its yield strength. It is a thermally activated process, meaning its rate increases significantly with temperature. In essence, it is the tendency of a solid material to move slowly or deform permanently under the influence of persistent mechanical stresses.
Key characteristics of creep are:
