Class 1 (Chief Engineer) Engineering Management 📅 Jul 2025
Define substantial corrosion in the context of ship structure and classification requirements. What criteria are used to assess substantial corrosion during inspections? Discuss the steps taken to address substantial corrosion during a renewal survey, including inspection techniques, repair methods, and the role of the classification society in ensuring compliance. (16)
### Definition of Substantial Corrosion
Substantial corrosion is a level of wastage in a ship's structural members that has progressed to the extent that it exceeds the allowable corrosion margin and compromises the structural integrity and safety of the vessel. According to the International Association of Classification Societies (IACS), it is defined as corrosion wastage exceeding 75% of the allowable margin.
* **Corrosion Margin**: This is the 'extra' thickness of steel added by designers beyond what is required for structural strength, specifically to account for expected corrosion over the ship's life. For example, if a plate requires 12mm for strength and is originally 15mm thick, the corrosion margin is 3mm.
* **Substantial Corrosion Threshold**: Substantial corrosion is reached when the wastage exceeds 75% of this 3mm margin (i.e., wastage > 2.25mm), meaning the remaining thickness is less than 12.75mm. When wastage reaches 100% of the margin (thickness is 12mm), immediate renewal is mandatory.
