Class 2 (2nd Engineer) MEKM 📅 Sep 2025
(a) Define the term Torsional Vibration with respect to an engine crankshaft, stating the effect that high levels can have on an engine crankshaft.
(b) Explain how engine deterioration influences the risk of Torsional Vibration, stating what can be done to minimise that risk.
(c) Explain TWO possible reasons for the activation of a Torsional Vibration alarm after an engine has been started if there had been no previous history of such an alarm and if no maintenance had been undertaken on the engine whilst it was stopped.
### (a) Definition of Torsional Vibration and its Effects
**Definition:**
Torsional Vibration is the periodic angular twisting and untwisting of a crankshaft along its longitudinal axis while it is rotating. This phenomenon arises because the torque applied to the crankshaft is not uniform but cyclic in nature.
**Mechanism:**
