Class 2 (2nd Engineer) MEKM 📅 Aug 2022
Describe a three element feed water controller (ie regulator) measuring steam flow, drum level and feed water flow and explain how a unity relationship is maintained between the three variables.
(b) Regulating Feed Supply
The feed supply to the boiler is regulated by a level transmitter connected to the boiler drum. This transmitter measures the current water level and sends a signal to a controller. The controller compares this measured value to a pre-set value (the desired water level). The output from the controller, which uses a flapper and nozzle mechanism , is sent to one of two feed regulators: a 7k line regulator for low-demand operation and an 18k line regulator for high-demand operation.
When the boiler is operating in low mode (7k) , the 7k controller is active and the 18k controller is completely shut. In this mode, the economizer pumps are used.
