Class 2 (2nd Engineer) MEKG 📅 Apr 2023
(a) Describe briefly the operation of an electrical or hydraulic main engine governor
(b) For the type described indicate how failure can occur and the action to be taken if immediate correction cannot be achieved and the engine must be operated.
### (a) Operation of a Mechanical-Hydraulic Main Engine Governor
A mechanical-hydraulic governor is a speed-sensing and actuating device that automatically controls the engine's fuel supply to maintain a set speed under varying load conditions. Its operation is based on balancing the centrifugal force of rotating flyweights against the force of a pre-compressed speeder spring.
#### Principle of Operation
The core principle involves a direct relationship between engine speed and the position of rotating flyweights. The centrifugal force generated by these flyweights is proportional to the square of the rotational speed ($$ F_c \propto \omega^2 $$). This force is used to control a hydraulic pilot valve, which in turn directs high-pressure oil to a power piston (servo motor). The power piston provides the significant force required to move the engine's fuel pump racks.
