(a) Describe the circuit breaker for an a.c. generator using a sketch to show how arcing is Controlled.
(b) Explain the sequence of events that might occur if the breaker opens on a short circuit and state the check you would require following such event
(c) Give a safe procedure to follow should a main circuit breaker fail to open under fault Condition.
### (a) Description of an AC Generator Circuit Breaker and Arc Control An Air Circuit Breaker (ACB) is the primary protection and switching device for a marine AC generator. It is designed to make and break the circuit under normal load conditions and to automatically interrupt the circuit under fault conditions like overload and short circuit. **1. Main Components:** * **Main Contacts:** These are silver-plated copper contacts designed for low resistance and continuous current carrying. They are the first to make and the last to break.
