(a) Describe the circuit breaker for an a.c. generator using a sketch to show how arcing controlled. (6)
(b) Explain the sequence of events that might occur if the breaker opens on a short circuit and state the check you would require following such event. (5)
(c) Give a safe procedure to follow should a main circuit breaker fail to open under fault Condition. (5)
