(a) Describe the effect of the following loads on power factor. (6)
(i) Induction motors
(ii) Transformers
(iii) Partly loaded motors
(iv) Cage type motors
(b) In a 50-kVA, star-connected, 440V, 3-phase, 50Hz alternator, the effective armature resistance is 0.25 ohm per phase. The synchronous reactance is 3.2 ohm per phase and leakage reactance is 0.5 ohm per phase. Determine at rated load and utility power factor (10)
(i) Internal EMF
(ii) No-load EMF E0
(iii) Percentage regulation on full-load
(iv) Value on synchronous reactance which replaces armature reaction
