Class 1 (Chief Engineer) Engineering Management 📅 Dec 2022
Describe the general structure of a Ballast Water Treatment (BWT) system, highlighting the following methods of treatment:
(a) UV treatment method
(b) Gas treatment method
(c) Electrolysys method
(d) Magnetic seperation method
### **Introduction to Ballast Water Treatment (BWT) Systems**
A Ballast Water Treatment System (BWTS) is an engineered system designed to remove, render harmless, or avoid the uptake or discharge of harmful aquatic organisms and pathogens within ballast water. The primary objective is to comply with the International Maritime Organization's (IMO) Ballast Water Management Convention, specifically the D-2 performance standard, which sets stringent limits on the concentration of viable organisms and indicator microbes in discharged ballast water.
### **General Structure of a BWT System**
A typical BWT system is installed in the ship's ballast water piping system and generally consists of two main stages, with a possible third stage depending on the technology used:
