Class 2 (2nd Engineer) MEKG 📅 Oct 2024
(a) Describe the preparation necessary before the application (in dry dock) of sophisticated or approved long life coating to the underwater surface of the hull: (6)
(b) State the significance of the roughness profile. (5)
(c) List the different sophisticated coatings which are available. (5)
### (a) Preparation Necessary Before Application of Long Life Coating
The preparation of the underwater hull surface is the most critical stage in ensuring the adhesion, longevity, and performance of a sophisticated long-life coating system. The objective is to produce a clean, dry surface, free of contaminants, with a specified roughness profile. The process involves the following key stages:
1. **High-Pressure (HP) Freshwater Washing:**
* **Purpose:** To remove all marine biological fouling (slime, algae, barnacles), loose or flaking paint, dirt, and especially, soluble salt contamination from the hull.
