Class 2 (2nd Engineer) MEKM 📅 Oct 2023
(a) Describe the procedure for entry into, and inspection of, the inside of a starting air bottle, stating the types of defects which may be present with their possible causes. (12)
(b) Describe the procedure of closing up the bottle and the initial pressurisation to working pressure. (4)
(a) Procedure for Entry into, and Inspection of, the Inside of a Starting Air Receiver:
Ensure the starting air receiver is disconnected from compressors.
Use at least two valves that can be locked off.
If not possible, remove any cross-connecting pipes and fit blanks.
