Class 2 (2nd Engineer) MEP 📅 Dec 2019
Describe the procedure for replacing a Main Engine cylinder liner and explain using sketches where necessary, those parts, which require close attention during lifting of cylinder liner. Also describe the procedure for pressure testing the cooling water side of the Main Engine Cylinder head.
