Class 2 (2nd Engineer) MEP 📅 Feb 2026
Describe the procedure to be undertaken by when, upon a routine schedule for changing Exhaust Valve on a main engine, it is found that the Exhaust valve body is seized inside the cylinder head and cannot be removed by conventional means and the internal threads in the exhaust valve body connecting to the exhaust bellows are damaged. (16)
### **Procedure for Removal of Seized Exhaust Valve with Damaged Threads**
This procedure outlines the systematic, safe, and professional approach required when an exhaust valve is found seized in the cylinder head and cannot be removed by conventional hydraulic tools due to damaged internal threads. The primary objectives are to remove the valve without damaging the cylinder head, ensure personnel safety, and restore the engine to a reliable operational condition.
#### **1. Immediate Actions & Safety Precautions**
* **Stop Work & Inform Superiors:** Immediately cease all removal attempts. Inform the Chief Engineer and Second Engineer of the situation.
