Class 2 (2nd Engineer) MEP 📅 Aug 2025
Describe the procedure to be undertaken when, upon a routine schedule for changing Exhaust Valve on a main engine, it is found that the Exhaust valve body is seized inside the cylinder head and cannot be removed by conventional means and also the internal threads in the exhaust valve body connecting to the exhaust bellows are damaged.
