Class 2 (2nd Engineer) MET 📅 Sep 2019
Diesel electric propulsion is now being chosen as the power plant for an increasingly wide variety of vessels.
(a) Sketch a simple layout of such an installation.
(b) Explain the advantages of selecting such a plant
(a) Electric propulsion system:(b) Advantages of Electric propulsion system:Economic ReasonsDiesel-electric systems allow for optimal fuel utilization even at low loads, ensuring cost-effectiveness during operations.They maintain high efficiency regardless of the engine's speed, making them suitable for variable operating conditions.The reduced complexity of the propulsion machinery leads to lower maintenance requirements and costs.The reduction in propulsion machinery size frees up more space for other uses, such as cargo storage or additional amenities.The system minimizes the likelihood of a complete loss of propulsion power, ensuring uninterrupted vessel operation.Environmental ReasonsDiesel-electric systems produce fewer emissions compared to traditional propulsion systems, contributing to reduced environmental impact and compliance with stricter emission regulations.Operational ConvenienceThese systems provide excellent responsiveness from zero to maximum speed, making them highly adaptable to dynamic operating conditions.Diesel-electric propulsion allows for shorter reversing times, improving manoeuvrability.They ensure quiet operation, enhancing onboard comfort for passengers and crew.Minimal mechanical vibrations lead to a smoother and more comfortable sailing experience.FlexibilityThe mechanical requirements of the shaft system are less complex, allowing for easier installation and maintenance.The design and engineering of the propeller are not constrained by the diesel engine, providing greater flexibility in system design.Operators can select from a wider range of diesel engines based on their specific operational needs and preferences.
