Class 2 (2nd Engineer) MEKG 📅 Jul 2023
Discuss some of the factors which effect the shaft alignment of ships propulsion shafting. Suggest the most effective methods adopted for achieving the best possible alignment? (16)
### Introduction
Proper alignment of a ship's propulsion shafting is critical for the reliable, efficient, and safe operation of the vessel. Misalignment induces significant stresses on the shafting, crankshaft, bearings, and hull structure, leading to premature component failure, excessive vibration, and potential catastrophic damage. The alignment process is not about creating a geometrically straight line from the engine to the propeller, but rather a carefully calculated 'fair curve'. This curve pre-compensates for various static and dynamic forces to ensure that the shafting system operates within acceptable bending stress and bearing load limits under all service conditions.
This answer is divided into two parts:
**Part A:** Discusses the factors which affect shaft alignment.
