Class 2 (2nd Engineer) MEKG 📅 Jan 2019
Discuss the causes of corrosion and the means by which corrosion of the following may be limited by manufacturers and ship's personnel respectively:
(a) Internal and external surfaces of auxiliary steam lines.
(b) External surfaces of auxiliary boilers.
(c) Water boxes of seawater coolers and condensers.
(d) Main sea water inlet pipes.
(a) Internal and External Surfaces of Auxiliary Steam Lines:
Causes of corrosion in Internal Surface:
