ETO ETO Exam papers 📅 Aug 2025
Discuss the fundamental principles and advantages of electrical propulsion systems in merchant vessels compared to conventional mechanical propulsion. What are some of the components that make up an electrical propulsion system? (16)
Fundamental Principles of Electrical Propulsion:
Electrical propulsion systems in merchant vessels replace the conventional main diesel engine with electric motors as the prime movers for the propeller. The system generally involves diesel generators (or gas turbines) producing electrical power, which is then supplied through transformers, converters, and advanced control systems to high-voltage propulsion motors. These motors directly drive the propeller shaft, thereby eliminating the need for a direct mechanical link between the prime mover and the propeller.
Advantages of Electrical Propulsion:
Instead of a large main engine, ships use comparatively small electrical motors of equal or greater output power, saving space and weight for cargo capacity.
