Class 2 (2nd Engineer) MEKG 📅 Oct 2019
Discuss the means by which corrosion of the following may be limited by manufacturers and ship's personnel respectively:
(a) Internal and external surfaces of auxiliary steam lines.
(b) External surfaces of auxiliary boilers.
(c) Water boxes of sea water coolers and condensers.
(d) Main sea water inlet lines.
(a) Internal and External Surfaces of Auxiliary Steam Lines:
Causes of corrosion in Internal Surface:
