Class 2 (2nd Engineer) MEKM 📅 Nov 2024
Discuss the nature of the forces to which a main engine crankshaft is subjected in normal service and explain how the resulting stress are maintained at a safe limit by design and efficient maintenance respectively. Indicate the circumstances under which the crankshaft may (16)
(a) Over stressed,
(b) Become defective without being over stressed.
Forces Acting on a Crankshaft in Normal Service
Inertia Forces :
These forces act on both the rotating and reciprocating masses of the engine.
For rotating masses, the inertia forces are constant in magnitude but change direction with rotation.
