During a routine crankcase inspection a main engine top end bearing is found to be wiped and subsequent inspection shows that the pin is badly scored.
(a) Explain in detail the action which should be taken to enable the engine to be safely operated so that the vessel may reach a port where effective repair facilities are available. (10)
(b) State with reasons the factors which influence the speed at which the engine may be safely operated. (6)
