Class 2 (2nd Engineer) MEP 📅 Jan 2026
Q4 During the overhaul of medium-speed auxiliary diesel generator you find that the white metal of one of the bottom end bearings has cracked. Explain how you would fit a spare bearing and enumerate the various tests you would carry before putting the machine back into service. (16)
### Introduction
The discovery of a cracked white metal bottom end bearing in a medium-speed auxiliary diesel generator is a critical defect requiring immediate and meticulous attention. The white metal (or Babbitt metal) is a soft sacrificial layer designed to protect the harder steel crankpin journal. Cracking can be caused by fatigue, overloading, poor bonding, lubrication failure, or corrosion. The following procedure outlines the surveyor-grade methodology for replacing the bearing and recommissioning the engine, emphasizing safety, precision, and adherence to manufacturer's standards.
A preliminary investigation into the root cause of the failure (e.g., analysis of lube oil, operational data, and inspection of other bearings) should be initiated to prevent recurrence.
### Part 1: Procedure for Fitting a Spare Bearing
