Class 2 (2nd Engineer) MEP 📅 Nov 2018
Explain in detail how you would isolate one of sprinkler system for routine maintenance. Describe all tests and inspections you would make and how you would return the system to service.
Isolation of the Sprinkler System
Sprinkler systems onboard are divided into multiple sections, each equipped with an individual isolation valve and alarm for easier maintenance. The following steps outline the procedure to isolate one section of the system for routine maintenance:
Inform the bridge about the planned maintenance, providing details of the section being isolated and the expected duration of the work.
Place the seawater pump in manual mode and switch off its breaker to prevent unintentional operation.
