Class 2 (2nd Engineer) MET 📅 Sep 2019
Explain the effect of reduced voltage on standard squirrel cage motors with respect to EACH of the following:
(a) Burn outs
(b) Starting current
(c) Starting torque
(d) Speed
(a) Burnouts:
Reducing the voltage supplied to a squirrel cage motor forces it to draw more current to maintain the same load. This is because power (P) is the product of voltage (V) and current (I): P = V x I. If V decreases, I must increase to keep P constant. The heat generated in the motor windings is proportional to the square of the current (I²R, where R is the resistance of the windings). Therefore, a significant increase in current due to reduced voltage leads to excessive heat generation. This overheating can damage the winding insulation, potentially causing a motor burnout.
(b) Starting Current:
The starting current of a squirrel cage induction motor is directly proportional to the supply voltage. Reducing the voltage proportionately reduces the starting current. This reduced starting current is beneficial because it minimizes stress on the motor windings and reduces voltage dips on the electrical distribution system. A lower power surge also prevents excessive power factor reduction. This gentler "cushion start" stabilizes line voltage. For example, a 50% voltage reduction results in approximately a 50% reduction in starting current.
