(a) Explain the factors you would consider in deciding whether to open up a cylinder unit for overhaul? After opening the unit and preparing for assembly, how would you decide whether to renew or re-use piston rings?
(b) List the causes of piston ring failure which may result in gas leakage or ring breakage.
