Class 2 (2nd Engineer) MEKG 📅 Nov 2023
(a) Explain the ideal design requirements of a ships propeller. (8)
(b) Briefly describe the propeller maintenance that should be carried out to prevent the fuel being wasted. (8)
### (a) Ideal Design Requirements of a Ship's Propeller
The ideal design of a ship's propeller is a complex compromise between maximizing propulsive efficiency and meeting structural, vibrational, and operational constraints. The goal is to convert the engine's rotational power into thrust with minimal energy loss. The key design requirements are as follows:
1. **Propeller Diameter:**
* **Principle:** For a given thrust, it is hydrodynamically more efficient to accelerate a large mass of water by a small amount than a small mass of water by a large amount. Therefore, a larger diameter generally leads to higher propulsive efficiency.
