Class 2 (2nd Engineer) MET 📅 Dec 2018
(a) Explain the preference for a 60 Hz system. Describe the dangers of running a 50 Hz system from a 60 Hz supply. (6)
(b) A ring-main, 900m long, is supplied at a point A at a p. d. of 220V At a point B, 240m from A, a load of 45A is drawn from the main, and at a point C, 580m from A, measured in the some direction, a load of 78A is taken from the main. If the resistance of the main (lead and return) is 0.25 ohm per kilometre, calculate the current which will flow in each direction round the main from the supply point A and the potencial difference across the main, at the load where it is lowest.
