(a) Explain the preference for a 60 Hz system. Describe the dangers of running a 50 Hz system from a 60 Hz supply. (6)
(b) A transistor amplifier stage comprises a transistor of parameters hie = 800Ω hfe = 50 and hoe = 20µS, and bias components and coupling capacitors of negligible effect. The input signal consists of an e.m.f. of 60 mV from a source of internal resistance 2.2 kΩ, and the total load on the stage output is 4 kΩ. Determine the current, voltage and power gains of the amplifier stage. (10)
