Class 2 (2nd Engineer) MEP 📅 Apr 2025
(a) Explain the purpose and working principle of the Load Dependent Cooling System (LDCS) in a two-stroke main engine. With the help of a diagram, describe how the system varies cooling water flow with engine load. (10)
(b) Discuss the advantages and disadvantages of using a load dependent cooling system over a conventional constant flow cooling system. What issues may arise if the system malfunctions, and how are they addressed? (6)
### (a) Purpose and Working Principle of Load Dependent Cooling System (LDCS)
#### **1. Purpose**
The primary purpose of a Load Dependent Cooling System (LDCS), also known as a Jacket Water Temperature Control System, in a modern two-stroke marine diesel engine is to maintain the surface temperature of the cylinder liners and combustion chamber components at an optimal level across the entire engine load range. This is critical for the following reasons:
* **Prevention of Cold Corrosion**: At low engine loads (e.g., during maneuvering, slow steaming), the combustion pressure and temperature are lower. If the cylinder liner surface temperature drops below the dew point of sulfuric acid (H₂SO₄), typically around 120-140°C, the sulfur compounds in the fuel (from HFO/VLSFO) and water vapor from combustion will condense as acid on the liner walls. This leads to rapid, aggressive corrosive wear of the liner and piston rings. The LDCS prevents this by actively keeping the liner temperature high during low load operation.
