Class 2 (2nd Engineer) MET 📅 Oct 2019
(a) Explain what is meant by the terms wave form, frequency and average value. (6)
(b) A moving coil ammeter, a thermal ammeter and a rectifier are connected in series with a resistor across a 110 V sinusoidal a.c. supply. The circuit has a resistance of 50 Ω to current in one direction and, due to the rectifier, an infinite resistance to current in the reverse direction. Calculate: (10)
(i) The readings on the ammeters
(ii) The form and peak factors of the current wave.
