(a) Explain why, in spite of accurate alignment under static conditions use of flexible couplings and copious supply of lubricant, main reduction gearing in still subject to pitting, scuffing and other tooth service. (8)
(b) Discuss the significance of viscosity in relation to the function of marine turbine oils as used in main propulsion installations, stating how the viscosity is controlled and what could cause it to change in service. (8)
