Class 2 (2nd Engineer) MEKG 📅 Feb 2023
(a) Explain with sketch, the operation of an automatic explansion valve as fitted in the direct expansion refrigeration plants. How is this valve adjusted
(b) Explain how critical temperture restricts plant operation and how these limitations can be overcome
(c) Explain how this system maintains the provision rooms at different temperatures
**Error Generating Answer:** Timeout of 600.0s exceeded, last exception: 503 failed to connect to all addresses; last error: UNAVAILABLE: ipv4:216.239.34.223:443: ConnectEx: Network is unreachable (A socket operation was attempted to an unreachable network.
-- 10051)
